AUDIO: mix skips at certain points
Cutting a music video: 4 min
FCP 4.5 HD
Video Has color correction
AUDIO: 3 LAYERS. L/R tracks. Imported a mp3 right from band mix. It sounds fine when played by itself.
Other audio layers do not mix with main tracks, they are just intro’s.PROBLEM – band mix jumps in certain spot when playback. remove everything but audio, still jumps. Play the mix by itself, it’s fine.
NOTES:
SCRUB sounds fine.
When I play back with video, it jumps. So I tried to isolate and mute L from R. Still hear it on both when in timeline.
I reimported the audio in, still jumps.
Removed all markers.
removed Video that was sync’d above it, so that there’s no video when the audio plays, still jumps.
When I 2x click and listen to actual clip, it’s fine. When it’s imported, with video or not, the clip jumps.
Created QT, and the mov has the jumps in it as well.HELP!!! Arguhh.
What can I do?
Does FCP change the audio in anyway when brining it into timeline?Thanks and great forum.
Chip
I have the clip posted if anyone wants to see what I mean.
