Activity Forums Adobe Premiere Pro Audio mix problem
  • Audio mix problem
    Posted by Eric Merklein on December 19, 2016 at 2:24 pm
    Good morning.
    I have an audio problem that I’ve never seen before.
    I created a new project as I always do, and imported clips from my Sony PMW200. The camera recorded two speakers, each having their own lav mic, and the lav outputs were plugged into 2 separate XLR inputs on the camera Ch1 and Ch 2.
    When I imported my camera sources into Premiere Pro, some reason the two separate audio tracks (ch 1 and 2) are showing up in one channel in clip mixer AND ch1 is panned left and ch2 is panned right. I can’t play either source in CENTER for mono output.
    Is there a setting that I don’t see, that would let ch1 and ch 2 be separate again and play back in center pan mode?
    This is a new one for me and, I’ll take any advice with gratitude.
    Thanks much.
    Eeric
    Many thanks.
    Simon Ubsdell replied 9 years, 9 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    December 19, 2016 at 2:41 pm
    Right click on the clip in the project panel – modify – audio channels.
  • Simon Ubsdell
    December 19, 2016 at 4:00 pm
    Try going to Clip/Modify/Audio Channels. You should be able to set it from there.
    Simon Ubsdell
    tokyo productions
    hawaiki
