Activity Forums VEGAS Pro Audio Merging
  • Audio Merging
    Posted by Andrew Goulding on May 28, 2010 at 3:29 pm
    I have 2 video clips that I want to place together, I have the first clip fading out and the 2nd fading in, when I click to drag the two clips together they merge and the fade disappears. Can this be avoided somehow? Many thanks.
    Andrew Goulding replied 16 years, 3 months ago 3 Members · 6 Replies
  • Mike Kujbida
    May 28, 2010 at 4:01 pm
    By click to drag the two clips together, do you mean that you drag the beginning of clip 2 over the end of clip 1.
    If yes, than what happened is what’s supposed to happen and can’t be changed.
    If it’s something else, please let me know.
  • Andrew Goulding
    May 28, 2010 at 4:22 pm
    I mean I drag clip 2 to the end of clip 1, not over it just so they are touching and there is no gap. Thanks for the reply.
  • Mike Kujbida
    May 28, 2010 at 5:31 pm
    I’ve had that happen to me before and have never been able to figure out why it happens.
    A re-boot usually fixes things so I’d try that.
  • Andrew Goulding
    May 28, 2010 at 5:44 pm
    Okay thanks, I will try that
  • Bob Peterson
    May 29, 2010 at 12:28 am
    You should probably zoom in very close to be sure they do not overlap. I would go at least to the point where you can see individual frames.
  • Andrew Goulding
    May 29, 2010 at 10:44 am
    Thanks, I tried the restart and that didn’t work but making sure there was a frame between them wasn’t visible in the end product and stopped the merging.
