Activity Forums Apple Final Cut Pro Legacy audio mapping output
  • audio mapping output
    Posted by Tom Dempsey on February 11, 2010 at 8:40 pm
    basically, i’m looking for some additional knowledge of fcp audio output. i captured 4 channels of discrete audio from a source and married it to video. now, i wish to output that sequence to a tape
    keeping all of the audio to its separate channels. if i choose “dual mono” will that not lower my output channels by 3db? would dual stereo be the correct path? any knowledge would be greatly appreciated.
    thanks,
    tomd
    Shane Ross replied 16 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    February 11, 2010 at 9:06 pm
    When you switch to Dual Mono, FCP by default bumps the audio +3db. Go into the SEQUENCE SETTINGS, Audio Tab and set your channel output.
    Then, in the timeline, right click between the lock and the auto select button to map what track of audio goes to what channel.
    Shane
