Activity Forums Adobe Premiere Pro Audio Loss on imported sequences – Premier pro cs4
  • Audio Loss on imported sequences – Premier pro cs4
    Posted by Tim Garrad on December 4, 2009 at 2:42 pm
    Hi Guys,
    I am using Premier Pro cs4 and I’m having a problem importing sequences I have made from other Premier projects. All the settings are the same for both projects.
    The problem is that I am getting no audio when I drag the imported sequence into the new sequence. All the files are nicely imported in their own folder/bin including the audio files, but no audio on the timeline. The visuals are all perfect including video,after fx and transisitons etc.
    Also I’ve expanded the audio track and it has one straight line and no waveform. I did the same on the imported sequence and it also displays no waveform???
    If anyone could explain how to sort this I’d really appreciate it.
    thanks.
    Vince Becquiot replied 16 years, 9 months ago 2 Members · 1 Reply
  • Vince Becquiot
    December 4, 2009 at 4:38 pm
    Close Premiere, then locate and delete your media cache folder(s).
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
