Activity › Forums › Adobe Premiere Pro › audio loses synch in multi-cam edit
  • audio loses synch in multi-cam edit
    Posted by Carly Smith on October 18, 2010 at 12:13 pm
    Hi all –
    I have a 4 camera edit setup in multi-cam editing, and they are using a separate audio track that does require precise audio synch (singers in close-up)
    Each section of video is about 1 hour plus, and the audio tends to lose synch about halfway through or so.
    We aren’t big enough to setup a full genlocked system, when shooting – its 4 cameras in an auditorium and a mixing board running the mics and capturing clean audio to a computer.
    Any suggestions on how to fix this issue in editing?
    Thanks in advance
    Carly Smith replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
