Activity › Forums › Apple Final Cut Pro › Audio Levels in Voice-Over Window
  • Audio Levels in Voice-Over Window
    Posted by Mike Drew on October 28, 2012 at 6:37 pm
    I just tried recording a VO in 10.0.6. The audio was fine, everything worked out but there was no audio level showing in the recording window. I have audio meters turned on in the timeline and they work fine for playback but nothing is showing while I’m recording. I tried it both using my Zoom H1 – works really well, by the way – as a USB mic and with the built-in mic but no levels show up.
    Levels worked in 10.0.5 but so far not in 0.6. I’ve tried re-starting a few times but no go. Maybe there’s something I need to turn on but I just can’t find it. The VO’s sound fine, the levels are where I want them but I’d sure like the level meter back in the recording window.
    Any ideas?? Loving this update otherwise.
    Eric Simpson replied 13 years, 11 months ago 2 Members · 3 Replies
  • Eric Simpson
    November 4, 2012 at 2:52 pm
    Have just encountered the same issue. Yesterday all was working as advertised, today no audio registering in the recording window.
  • Mike Drew
    November 4, 2012 at 4:09 pm
    I should have posted my solution earlier but your post reminded me. What I did was restart X, open the VO recording window and cycle through the options for stereo and mono and suddenly the levels popped on. I haven’t had a problem since. Not a very scientific or logical solution but it worked for me. Hope that helps.
  • Eric Simpson
    November 4, 2012 at 8:39 pm
    Thanks, worked for me too!
