Activity Forums Apple Final Cut Pro Audio Levels and Compound Clips
  • Audio Levels and Compound Clips
    Posted by Scott Reynolds on August 11, 2013 at 11:23 pm
    I’ve observed some rather odd audio level behaviour with compound clips and was wondering whether anyone has noticed something similar.
    My project is a set of compound clips. **Within** each compound clip I have set the audio levels to an appropriate level and verified through the meter for each audio clip.
    However when I play the compound clip at the project level, the levels are lower (by almost 6dB) than when I play the same at the clip level.
    Even more strange is that if I break apart the compound clip, the audio levels remain at the “lower” values.
    I’m sure I am missing something very basic here, so would appreciate any pointers you may have.
    Regards,
    Scott
    Scott Reynolds replied 13 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
