Activity Forums Apple Final Cut Pro Legacy audio levels
  • Posted by Tony Sawicki on March 10, 2010 at 3:52 pm
    What is the fastest way to “even out” audio levels in FCP, ie, to make the entire audio “clip” even at -12 dB, or is this even possible without going through the audio clip and manually adjusting the levels? Thanks for the help, this could save me a lot of time.
    Adam Taylor replied 16 years, 6 months ago 5 Members · 4 Replies
  • Rob Grauert
    March 10, 2010 at 5:28 pm
    you could try:
    Modify > Audio > Apply Normalization Gain. This will adjust the audio of your clip so that the loudest part does not exceed the value you set
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Brian Pitt
    March 10, 2010 at 6:41 pm
    I would export the audio into Soundtrack Pro and add a Limiter filter. It’s a little more work, but you get much better results than you do in Final Cut.
    Brian
  • Michael Gissing
    March 10, 2010 at 10:02 pm
    All you are doing is setting the maximum peak to a fixed setting. That isn’t going to make for a mix or balance. Peak levels do not equate to apparent loudness.
    Just like grading is a shot by shot interpretation using scopes, audio is also an interpretive art using meters to help and also to check for tech acceptance.
    EQ & Dynamics control via compressor/ limiters are how to get both a balance and be within tech acceptance. It is just as much an art as grading or editing so either pass it on to a pro or spend the time to make it right. After all sound is much more than 50% of your final work so either take it seriously or get out of the way and let a sound post pro take over.
    Ironically it is the cheapest way to add value to your production and the skill that many editors seem to lack. Ignorance about sound is a constant amazement to me.
  • Adam Taylor
    March 11, 2010 at 9:22 am
    “…sound is much more than 50% of your final work so either take it seriously or get out of the way and let a sound post pro take over.
    Ironically it is the cheapest way to add value to your production and the skill that many editors seem to lack. Ignorance about sound is a constant amazement to me. ”
    Hallelujah, Amen and Praise be!!
    truer words are rarely written.
    Take heed, for the wise hath bestowed the gift of knowledge upon thee.
    Use it well.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
