Activity Forums Adobe Audition audio level puzzle
  • audio level puzzle
    Posted by Daniel Zimmerman on June 21, 2015 at 7:39 am
    I’ve been given an audio spec that states audio level should average around -12dB, and lower than -6dB. Trouble is, how do I decide if the average is around -12dB? In Audition, I used to look at the levels meter and see if the level was oscillating around -12. But later I learned to use the Single-band Compressor effect and became more confused because the result depends on attack/release time.
    My question is, is the spec I was given a reasonable spec? Also, is there an easy way to tell average level?
    Thanks for your help.
    Daniel Zimmerman replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
