Activity Forums Apple Final Cut Pro Legacy Audio Level Problem FCP AJA
  • Audio Level Problem FCP AJA
    Posted by Ben Dittrich on May 9, 2007 at 9:57 am
    Hello all.
    I have a problem with digitzing & mastering Audio, my audio levels are not the same when i master, as the digidized clip was.
    In our facility we are working with an 1kHz -9dB Level for Sinus Tone… my System is a G5 Quad Core with a AJA Kona LHe Card and an Apple Raid System.
    When i was digitizing the Audio everything seemed to be fine, but when i was playing my Test Clip the levels were -12dB instead of -9 dB.
    Or they are -6dB, when i setup Analog Audio Monitor Levels to +24 dBu FSD in the Kona Setup
    When i then edit the clip to Tape, the Levels are not longer -9dB, they are -15dB
    Has somebody experienced a similar problem, or has an idea how to solve this?
    Benjamin
    Ben Dittrich replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
