Activity › Forums › Apple Final Cut Pro Legacy › audio lay-back to DVcam
Posted by L Isha on April 26, 2005 at 7:03 pmHello to all,
Is it possible to do an audio lay-back to a DVcam without affecting the picture?
Thanks so much,
LishaL Isha replied 21 years, 5 months ago 3 Members · 5 Replies -
Shane Ross
April 26, 2005 at 8:10 pmOnly on high end decks like the DSR-1800.
But as to how to do that with FCP…dunno. Only worked on an Avid with that deck…
Rienk Leendertse
April 26, 2005 at 8:41 pmShould work on high-end decks, as said. But only via RS422. Firewire doesn’t support insert edits (as far as I know).
Rienk
L Isha
April 26, 2005 at 9:07 pmThanks guys!
Yes, I am going to use a DSR-1800. So is it the same concept as when I work with a digi-beta? Actually the audio mixer is going to do the lay-back. Usually we work with digi-beta.
Lisha
L Isha
April 30, 2005 at 4:51 pmThinking out loud… Feel free to chime in. 🙂
The back story…I’ve been editing a TV show for over a year. Usually I make a DV-cam master, take it to a post house and have a digi-beta created. Then the audio mixer works with the digi-beta. Then I take the mixed digi-beta to the post house and they make another digibeta, closed caption it, QC it and satellite it. I am trying to alleviate the first digi-beta transfer and have the audio mixer lay-back to the DV-cam.
Since I don’t have an RS422, I was going to make my master on a DV-cam via firewire using a DSR-11. However if I do this can the audio mixer still do an audio lay-back using the 1800? As I am sitting in my edit bay talking to myself my thoughts are that this is not possible. Am I correct in that I would need to make the master via RS422 using the 1800 so the audio and video channels are separate?
Any thoughts?
LishaDual 1 GHz PowerPC G4
1 MB L3 cache per processor
1.5 GB DDR SDRAM
2 120 gig Lacie external drivesFCP HD/4.5/dv
DSR-11
OS 10.3.5After Effects 5.5
Photoshop 6.0
