Activity Forums Adobe Premiere Pro Audio Latency
  • Audio Latency
    Posted by Lee Schneider on September 23, 2015 at 11:15 pm
    I just purchased a new monitor and my synch is off. I’m running the most current version of PProCC on a year old MacPro. Coming out of the Mac into a PreSonus Firestudio. The audio is ahead of the video playback and I’ve been searching all over in the preferences and can’t figure out how to adjust the latency and bump the audio back a bit. Obviously it’s driving me nuts! lol Any help would be greatly appreciated.
    Lee
    Lee Schneider replied 10 years, 11 months ago 2 Members · 4 Replies
  • Simon Billington
    September 24, 2015 at 12:58 pm
    Have you tried setting the FireStudio as the Master Clock on the Audio Hardware preferences??
  • Lee Schneider
    September 24, 2015 at 2:13 pm
    Yeah I have the FireStudio set as the Master Clock. I’ve tried a lot of things, just can’t figure it out… and of course it’s a nightmare to try and edit this way. lol
  • Simon Billington
    September 25, 2015 at 1:14 am
    As a work around, you try placing a delay plugin on your master out, fiddle with it until the Audio falls back into sync.
    Oh, if you do that, remember to bypass it when you want to render out.
    I’m getting the impression the problem may jot be audio, but there is lag time for with the monitor. Perhaps it’s the type of cable used, but I don’t really know what your options are.
  • Lee Schneider
    September 25, 2015 at 12:45 pm
    Simon, that’s a perfect quick fix workaround, thanks. It’s definitely a monitor issue as my previous one didn’t have a lag. I just purchased a 4k monitor and have it connected to the MacPro via HDMI and there’s probably a better way to connect it, so I’m all ears if you have a suggestion. Thanks again!
    Lee
