Activity Forums Apple Final Cut Pro Legacy Audio Latency w/ Intensity video & Edirol firewire audio monitoring?
  • Audio Latency w/ Intensity video & Edirol firewire audio monitoring?
    Posted by Sam Alexander on April 6, 2008 at 11:04 am
    Hi all,
    I’m a bit new to my hardware and FCP but was curious if anyone knew if I would experience any audio latency in scrubbing or playback if I setup FCP to use my Blackmagic Intensity Pro card for video and my Edirol FA-101 firewire audio interface to monitor the audio? I mean will the sound even be off a frame or am I just paranoid of using two different devices for audio & video moitoring.
    I just love the Edirol for my audio work and have it plugged into my mixing board – but the Intensity Pro only has analog audio out – right?
    thanks for any advice.
    Sam
    Sam Alexander replied 18 years, 5 months ago 3 Members · 3 Replies
  • Philip Johns
    April 6, 2008 at 12:03 pm
    Not sure my self but will be watching this space to know if anyone knows. I did speak to a tech support guy from Black Magic and he told me that the Motu would sync perfectly with my card (it’s an Intensity card so should be in the same basket as yours). The edirol looks very similar to the Motu.
    Cheers
    Philip Johns
  • Russell Lasson
    April 6, 2008 at 9:28 pm
    It might work just fine, but you might be asking for problems. I’d rather just use the audio from the Intensity card unless I wanted to only record audio, then I’d plug in Edirol. I say this because if anything was ever out of sync, I’d always have to wonder if it’s the hardware or the video clip.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Sam Alexander
    April 11, 2008 at 8:54 am
    thanks – my thoughts exactly. I think I’ll use the Intensity Pro’s output for now until I have time to try some comprhensive tests. When I do get time to test it very thorughly I’ll post my results here in case anyone is interested.
    Just after a bleary-eyed long editing session I’d be afraid there were a few milliseconds out or something and I’d have no way to be sure.. :p
