Activity Forums Apple Final Cut Pro Audio keyframes- change default keyframe easing
  • Audio keyframes- change default keyframe easing
    Posted by Jim Bachalo on July 23, 2014 at 11:20 pm
    One thing thats always bothered me with the default keyframes is the easing. Is there any way of changing this? Why can’t Apple give us bezier curves to adjust like in After Effects?
    You should follow me on Twitter here. My latest work
    Robin S. kurz replied 12 years, 1 month ago 2 Members · 1 Reply
  • Robin S. kurz
    July 24, 2014 at 10:18 am
    As opposed to any other NLE I’ve used, where there was none at all? 😀
    And if you’re using the fade handles, you have four different curves to choose from. Seems pretty unlikely to me that none of them wouldn’t suffice.
