Activity Forums Adobe Premiere Pro Audio keyframe bug in PP2015
  • Audio keyframe bug in PP2015
    Posted by Andrew Berekdar on January 8, 2016 at 4:32 pm
    When I write audio volume keyframes to a track (either in realtime using the write / touch option in the audio track mixer) or using the pen tool, premiere is intermittently reading them and seems to get stuck on certain keyframes where it sicks to a certain volume until I pause and play the sequence again, when it jumps back to the correct volume….until the next time I pause the sequence.
    I’ve tried duplication the sequence but I’m getting the same problem. I’ve tried deleting plists and restarting the application…
    Here is a video demonstrating the problem…any suggestions would be very welcome!
    https://youtu.be/OehAoewakrU
    Andrew Berekdar replied 10 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
