Activity › Forums › AJA Video Systems › Audio issues using U-Matic VO-7600 and FCP
  • Audio issues using U-Matic VO-7600 and FCP
    Posted by Michael Spears on June 3, 2010 at 2:25 pm
    Hello,
    We are digitizing old 3/4″ news tapes at my archive and are having issues capturing audio into FCP. We are using NTSC uncompressed 8-bit and are connected through XLR. When capturing (we are capturing the whole tape and not logged clips) the audio levels are around -60. As well during playback the levels stay this low and barely any audio is heard through the monitors. Are anyone else having this problem and if so is there a solution?
    Regards
    Michael Spears
    Archives Assistant
    MDC’s Lynn and Louis Wolfson II Florida Moving Images Archive
    Jeremy Garchow replied 16 years, 4 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    June 3, 2010 at 4:06 pm
    [Michael Spears] “Are anyone else having this problem and if so is there a solution? “
    Using an io or ioHD?
  • Michael Spears
    June 3, 2010 at 4:08 pm
    Sorry I should have mentioned that in my first post, it is just an IO.
    Michael Spears
    Archives Assistant
  • Jeremy Garchow
    June 3, 2010 at 4:28 pm
    Do you have the control panel installed?
    Have you chose the proper analog easy setup?
    Do you have a mixer in between the deck and the io?
  • Michael Spears
    June 3, 2010 at 5:40 pm
    We are running firmware 3.1 and control panel 1.2. We had it through an external mixer before, and still had fine levels on the mixer, but no sound during the capture.
    Michael Spears
    Archives Assistant
  • Jeremy Garchow
    June 3, 2010 at 5:45 pm
    Are you sure that you have the analog audio easy setup and have xlr analog in chosen in the control panel?
