Activity Forums AJA Video Systems Audio Issue, SDI-Kona LH
  • Audio Issue, SDI-Kona LH
    Posted by Hugo Tabares on August 1, 2006 at 2:05 pm
    Hi Guys, first time using 1080i material.
    Shot with Canon XLH1, 1080i.
    Trying to digitize in Final Cut 5.1.1, with Kona LH using its SDI input.
    Issue: I got Video BUT NO AUDIO AT ALL.
    I see levels on the Cam just fine, but the AUDIO signal gets lost and won’t come thru the SDI.
    It may just be a Simple fix…Again it’s my first time.
    thanks a lot in advance
    DB
    Bob Zelin replied 20 years, 1 month ago 5 Members · 5 Replies
  • Walter Biscardi
    August 1, 2006 at 2:37 pm
    Go into your Kona Control Panel and switch the audio to Embedded. Default is AES.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
  • Hugo Tabares
    August 1, 2006 at 2:51 pm
    I did try that..and Nothing.
  • Christopher Tay
    August 1, 2006 at 3:44 pm
    Does the HD-SDI output from the Canon XLH1 carry embedded audio ? If it doesn’t, then your only option is to take the analog audio and feed it to the Kona LH analog audio input via an audio mixer since it is an unbalanced output. Then change the audio input on the AJA Control Panel to analog.
    -chrispy
  • Jeremy Garchow
    August 1, 2006 at 3:52 pm
    [chrispy] “Does the HD-SDI output from the Canon XLH1 carry embedded audio ?”
    Nope, it does not. Do what Chrispy says and use the analog audio.
  • Bob Zelin
    August 2, 2006 at 1:50 am
    The Canon XL-H1 DOES NOT put out embedded audio. This is an assumption that I made recently, and I WAS WRONG. The Canon XL-H1 puts out ANALOG AUDIO – no embedded SDI audio.
    Crazy? Complain to Canon – I did.
    Bob Zelin
