Activity Forums Apple Final Cut Pro Legacy audio is out of sync in final cut
  • audio is out of sync in final cut
    Posted by Klaus Jack on August 9, 2010 at 2:51 pm
    Hello I have a problem with the audio files of a project in Final Cut and would appreciate any help or suggestion for the following problem
    I was given a video to edit which has audio tracks from the camera mike which is obviously in sync
    However there was also external sound recording with the Zoom H2 and 4 tracks of wireless mikes …
    The sound recorded with the camera shows up as a quicktime 48kh 16bit
    The sound recorded with external equipment shows up as itunes file 48 kh 24bit
    (They were converted to send)
    This conversion i believe has somehow that made them be out of sync. Even if i sink one part it does not stay in sync for long
    Has something happened during the conversion to i tune format ???
    Is it the 16bit 24bit difference???
    I could of course ask the person who sent me the files to send them unconverted but was wondering if there might be a solution that someone has come across ???
    Cheers
    Klaus
    Well has anyone got an idea how to solve this maybe reconvert the files ???
    John Fishback
    replied 16 years ago
    3 Members · 3 Replies
  • Michael Gissing
    August 10, 2010 at 2:03 am
    By iTunes format do you mean aac or mp3? The files should be 48khz aif or wav files, either 16 or 24bit.
    Avoid anything but uncompressed wav & aif and everything must be 48khz including the timeline to avoid problems in FCP.
  • Klaus Jack
    August 10, 2010 at 10:09 am
    OK yes not itunes
    They are wav files they just come up as itunes format if i open properties in final cut
    When i reveal in finder and go to properties they are wav files
    There is a difference in data rate (could this be a problem) ????
    The camera files are 5,9 MB sec 48 KHz 16 bit (part of mov file from camera)
    Data rate of the zoom files is 187,5 KB per sec 48KHz 16 bit (wav files)
    Data rate of wireless mikes is 562,5 KB per sec 48KHz 24 bit (wav files)
    Audio settings of the project are 16 bit 48KHz stereo…
    Cheers
  • John Fishback
    August 10, 2010 at 4:58 pm
    Her’s a fix that Jeremy Garchow suggests that has worked for others. Usually, it’s happened with 23.98 (actually 23.976) timelines, but substitute your frame rate if different.
    “First, delete the new mix out of FCP and your timeline. Set FCP up in a 23.98 easy setup, then quit FCP. Now reopen FCP and reimport your new mix.
    The file should be in sync.”
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
