Activity Forums Media 100 Audio into M100 via Kona Lhe -hlp please
  • Audio into M100 via Kona Lhe -hlp please
    Posted by Paul Crowe on June 24, 2011 at 1:03 am
    Ok. I’ve got issues getting audio into Media 100 via the kona lhe box.
    Here’s the situation: I’m running a mic from a voice over booth into the channel 1 analog input of the Kona box, out of the chanel 1 analog output to a desk which then outputs to audio monitors.
    Thing is when I’m in acquire mode in m100 I can hear it through the monitoring speakers fine (but not hear anything when out of acquire mode). so by my way of thinking it’s getting to m100 but there are no levels in m100 audio monitor interface.
    I’ve got the M100 prefferences set as follows: Audio Input analog, Input channel mapping set to channel 1 only (no video), audio output set to knoa lhe breakout monitoring 1&2, sync audio to analog with “enable system sound device” checked. Device control set to no machine.
    In my head it seems like this should work becasue I’m only hearing it in acquire mode, but as I say no-levels in the M100 audio monitor.
    It’s M100 suite 1.7 on a quad-core intel running OSX 10.6.7
    Any help with this would be very, very greatly appreciated.
    Cheers
    Paul
    Floh Peters replied 15 years, 2 months ago 2 Members · 3 Replies
  • Floh Peters
    June 24, 2011 at 8:32 am
    Try turning on the video input (and give it some sort of signal). I seem to remember that there were some issues with some Kona drivers with audio-only input.
  • Paul Crowe
    June 27, 2011 at 3:01 am
    Ok right. Thanks for that Floh.
    Hmm, at the moment all I think I can get my hands on for a signal is an EX3. If I switch it to cam and take a SDI out should that do for a signal?
    Cheers
    Paul
  • Floh Peters
    June 27, 2011 at 10:37 am
    That should work. Or a Composite out from a DVD player or anything else.
