Activity › Forums › Audio › Audio interface and camera compete for FireWire…
  • Audio interface and camera compete for FireWire…
    Posted by Phillip Grey on July 26, 2009 at 10:14 pm
    I really couldn’t think of a more appropriate forum to post this in, so I hope it’s fine although the issue itself doesn’t necessarily pertain to audio. Also, the topic title is probably a bit confusing, but I couldn’t think of anything better to title it. So here is the situation:
    I have a M-Audio FireWire 410 audio interface and I use a Canon ZR800 miniDV camcorder to capture video as well as use it as a medium for an external monitor (a CRT television).
    A problem has irritated me for a very long time and I’ve finally decided to ask if the problem is fixable. So now, here is the problem:
    The interface and the camcorder will not function when plugged in at the same time. That is, I must choose to either have audio out of my interface or use my camera to capture or preview footage on a television. I can never run both at the same time, which is very frustrating.
    Further symptoms:
    – Running both at the same time results in videos that won’t play
    – The camera never receives the video signal regardless
    – Audio ceases to play
    At that point, I can’t merely disconnect the camcorder. I have to restart, which also becomes harder to do.
    I am hoping there is some type of setting I can do to remedy this dilemma. My external hard drive runs off FireWire, as well, and it never has a problem with either of them. Any and all advice is greatly appreciated!
    Thaxter Clavemarlton replied 17 years, 2 months ago 3 Members · 2 Replies
  • Peter Groom
    July 27, 2009 at 8:31 am
    Id have thought you need a motherboard that natively supports multiple firewire streams.
    Peter
    Peter
  • Thaxter Clavemarlton
    August 1, 2009 at 1:01 am
    [Phillip Grey] “The interface and the camcorder will not function when plugged in at the same time.”
    It is generally against FW protocol to operate a video FW device AND another active “A/V” FW device at the same time.
