Activity Forums Adobe After Effects Audio in After Effects
  • Audio in After Effects
    Posted by Michael Hendrix on June 21, 2006 at 8:04 pm
    I am working in Windows on a laptop (Dell M70) 2 GB of RAM. When I do a RAM preview with audio, it will play the video but I get an AFter Effects error message (10:65) that says “This machine’s sound capabilities do not include playback of stereo audio.”
    It started doing this a few weeks ago, I upgraded to 7.0, still does it. Any have any idea?
    Audio will play in all other applications, doesn’t matter the file format, i have changed the settings in preferences to mono, and I get a different message that says “audio output problem. A device ID has been used that is out of range for your system.”
    Not too sure what might be the problem. Any suggestions would be a great help.
    Michael Hendrix replied 20 years, 3 months ago 3 Members · 6 Replies
  • Matty Stevens
    June 22, 2006 at 8:02 am
    did you try hitting 0 on your keypad once to get it to render then again to preview with sound?
  • Michael Hendrix
    June 22, 2006 at 6:11 pm
    Nope, still won’t work. I may have to reinstall.
  • Kjones
    June 23, 2006 at 8:24 pm
    HI, I’m having the exact same problem.
    At first i thought I wasn’t formating my audio properly in Audition, before I imported into AE (since I’m a total rookie) but I’ve re-done this a few time and nothing changes.
    I’m wondering if might have anything to do with my sound card, since it caused a lot of problems when I intially installed Production studio on my PC.
    If anyone had a solution PLEASE help.
    Kait
  • Matty Stevens
    June 23, 2006 at 9:59 pm
    is the sound in mp3 format? you have to have your sound file converted to .mov (quicktime) or .wav format. you can do that in priemere by saing export>audio and choosing correct settings. but when in AE i had the same problem untill i hit (0) for it to render first then hit (0) again to play back. but if i just hit play there will be no sound.
  • Kjones
    June 23, 2006 at 10:54 pm
    I’m using .wav files. It doesn’t seem to matter whether I render and then play back (0 then 0) or just play back (.) is still get the same message:
    After Effects error: audio output problem. the specified format is not supported or cannot be translated. Use the Capabilites function to determine the supported formats.
    (10 :: 65)
    I realize its not the exact same message as above, but I thought it was pretty similar.
    I thought it might be a problem with Quicktime 7, since I’ve seen that other people were having problems with that, so I uninstalled QT and installed and earlier version but still no luck.
    The really weird part is if I export the project into Premiere the audio works, its just won’t play in AE.
  • Michael Hendrix
    June 26, 2006 at 2:04 pm
    Yep, I’ve tried several formats and the same thing. Just can’t figure it out so now I am timing in Audition.
