Activity › Forums › Adobe Premiere Pro › audio import problem in Premiere Pro CS3
  • audio import problem in Premiere Pro CS3
    Posted by Tucker Boyd on May 8, 2009 at 7:07 pm
    I am working on a project in CS3 and when I import a mpeg clip with linked video and audio, the audio is absent when I try to play it. The icon appears on the clip containing both audio and video, but there is not any audio. When the clip is played outside of CS3, everything plays great. Also, I have had not had these problems importing avi files. Any thoughts?
    Tucker
    Travis London replied 16 years, 11 months ago 4 Members · 5 Replies
  • Ann Bens
    May 8, 2009 at 7:31 pm
    If the mpeg audio contains ac3 then install the ac3 filter codec.
  • Tucker Boyd
    May 8, 2009 at 7:35 pm
    Thanks…I’ll try that
    Tucker
  • Tucker Boyd
    May 8, 2009 at 7:57 pm
    That did not seem to work. Any other thoughts?
    Tucker
  • Adrian Sancho
    May 9, 2009 at 6:02 am
    I used to have a similar problem exporting mpeg files in quicktime pro to either an .mov or other format. Some other programs wouldn’t see it either. I believe it has something to do with the way the audio is multiplexed with the video.
    My solution was to use TMPGEnc mpeg encoder to extract the audio from the mpeg file and save it as an uncompressed .wav.
    If you think you might want to go this route, you can get a free version of the encoder here:
    https://www.tmpgenc.net/en/download.html
    This version needs no installation. Unzip to it’s own folder and run.
    If you need to read a quicktime file into TMPGEnc, you’ll need to install this plugin for it here:
    https://www.moviecodec.com/downloads/363d.html
    Unzip the QTReader.zip file and put it in the TMPGEnc folder.
    Load in your mpeg file into TMPGEnc and click ES (Audio only) in the STREAM TYPE. Click the SETTINGS tab and choose Linear PCM. OK that, set your output destination, and hit the START button.
    I’ve placed a screen grab below to show you. You may need to click it and possibly expand it’s viewing box to see sufficient resolution. This is a screen grab of both the main program window on the left and the audio settings on the right.
    After writing all this I didn’t think of whether you are on a MAC or not. Hopefully not. 🙂 Well, hope this helps.
  • Travis London
    October 13, 2009 at 6:15 pm
    i seem to have the opposite problem. for some reason certain avi, mp4, (and probably others) only have sound when i import, and the icon is strictly sound. though, other avi files work.
    is there a patch i can download?
