  • Posted by Yountz on October 26, 2006 at 4:19 pm
    Cannot figure this one out… have a song in mp3 format. when i play it through itunes sounds fine no audio hit. When i put it in the preview window in FCP no hit. When I drop it into the timeline there is a hit. The waveform view has no spike either. any help is appreciated.
    Jeff Carpenter replied 19 years, 11 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    October 26, 2006 at 4:25 pm
    Use iTunes (or Quicktime) to convert it to the same standard as your Final Cut sequence. Most likely that means a 48 kHz AIFF. Then, import the converted version and use that to edit with.
