Audio havoc/out of sync issues when CS 5.5 imports CS 3.2 projects
Greetings,
This is driving me nuts.
Source: AV sync is perfect for the entire timeline in CS 3.2.
After being imported into CS 5.5 and the dust settles, some of the programs segments/clips are fine and some are now messed up which can’t be resynced without an enormous amount of effort if ever!
Are there any ideas what may cause this random and unpredictable synce mayhem?
What really irks me is that it’s so inconsistent and entirely unpredictable as sometimes the entire import is fine and at other times it fails.
BTW: I’m not doing anything different processing and editng-wise from one project to the next as my workflow and procedure is the same.
