Activity Forums Audio Audio has an echo
  • Audio has an echo
    Posted by Gina Miller on December 20, 2012 at 4:11 pm
    I’ve got an audio narration that has an echo on it. I’ve been trying to get rid of it for the last three days, Can anyone help… Thank you
    Peter Groom replied 13 years, 9 months ago 5 Members · 6 Replies
  • Brian Reynolds
    December 20, 2012 at 10:37 pm
    Is the ‘echo’ slightly before the voice (a common problem with some analogue tapes) or is the echo actually room noise or a poorly recorded voice or has it been artificially been put there, is the track a stereo or mono track?
    Is there any chance you can post some on line so we can have a listen.
  • Mark Spano
    December 20, 2012 at 10:39 pm
    Can’t do a lot for that problem. I can suggest a plugin that has sometimes helped but with limited expectations.
    SPL’s De-Verb
  • Gina Miller
    December 20, 2012 at 11:24 pm
    Brian, I tried to put it on here but it didn’t work – can I email it to you?
  • Peter Groom
    December 21, 2012 at 9:32 am
    Id not expect much joy with this unless its something basic like 1 leg has slipped to the other and youre listening to a LR stero file in mono. That whould be easy, but if it is truly on the same recording then youll need a re voice.
    At least a vo is re doable, not like a shoot etc.
    If its been supplied to you externally then just reject it and get the supplier to sort it if its his problem.
    Peter
    Post Production Dubbing Mixer
  • Richard Crowley
    December 21, 2012 at 3:45 pm
    Post your sample on a public file-sharing website and post the link here. Without hearing the sample, we can offer only wild speculation. Don’t get your hopes up that the problem can be fixed in post-production editing.
  • Peter Groom
    December 22, 2012 at 9:43 am
    A tick has appeared by my last post.
    Was that really it?
    Peter
