Activity Forums Adobe Premiere Pro Audio hardware/Harman-Kardon Soundsticks 1
  • Audio hardware/Harman-Kardon Soundsticks 1
    Posted by Chad Kappeler on May 3, 2017 at 3:07 pm
    Is there any way to use a set of Harman-Kardon Soundsticks 1 with Premiere? When I try to set them as the audio output I’m warned that they don’t support the sample rate. I don’t seem to have any problem with the Soundsticks on any other applications. They play 24-bit/192kHz audio files out of iTunes with no problem. I’m using an early 2008 Mac Pro 3.1 running OS X 10.11.6 with 20 gigs of ram and the latest version of Premiere.
    Chad Kappeler replied 9 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
