Audio glitches or “Pops” in Sound Forge 9 recording
Posted by Will Hunter on September 13, 2010 at 7:57 pmI record 30 minute vo over sessions for training presentations. Recently I started encountering digital “pops” or glitches in the recording. I have not changed any SF settings or hardware changes. It doesn’t seem to coincide with a level change in the narration. Is anyone familiar with a bug or any possible solutions? I have tried audio restoration and crackle fix but they don’t do a good job of deleting a digitial pop in the audio track.
Any suggestions would be much appreciated,
Will
Ty Ford replied 15 years, 11 months ago 3 Members · 15 Replies -
Ty Ford
September 14, 2010 at 11:51 amHello Will,
Can you post some links to examples?
Regards,
TyFord
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitar -
Will Hunter
September 14, 2010 at 3:37 pmHere is another bit of information. To eliminate the mic and xlrs, i played back a clean audio session from last year via windows media player and recorded it in sound forge. When i played it back, I got glitches around 18:00 and 25:00 minutes into the session.
Peter Groom
September 14, 2010 at 4:13 pmOK
The glitch goes right through the spectral display of the audio, so its not acoutsically generated.Izotope RX does a pretty good job of eliminating it.(on the sample you posted. Not 100% but way way better than the original. Nothing that a low wash of some relaxed music wouldnt mask.
I dont know whats causing it, but id be checking the demmands on your RAM / CPU. It may well be a bussing issue where the pc is struggling to record and store the data.
Peter
Peter
Ty Ford
September 14, 2010 at 4:30 pmPeter,
I think you’re on to something. Macs I use don’t seem to haver this sort of problem, but I have seen it on PCs.
Also, if the work is being don on a computer with only one hard drive and not enough ram, this sort of thing can happen.
Check the recommendations of the software for what sort of minimum platform they suggest.
Regards,
Ty Ford
Will Hunter
September 14, 2010 at 4:38 pmI have Audacity on my computer. Is it a good enough program for recording voice overs? I don’t use Sound Forge for anything other than audio capture.
Will
Peter Groom
September 14, 2010 at 4:49 pmset it recording and then hit ctrl + alt + del to bring up the task manager. look at system performance and what processes are running, just to see if the machine is copeing easlil. Also, are you recording audio to the c drive. That is a big No no. Always run just the operating system and software on c: and audio rec and playback from another drive, internal or external.
Let us know what you find.
PeterPeter
Will Hunter
September 14, 2010 at 8:21 pmAny thoughts on using Audacity as a software for recording VO for training courses?
Will
