Activity Forums Adobe Premiere Pro audio from hd footage is just static
  • audio from hd footage is just static
    Posted by Marc Marcus on January 18, 2014 at 6:32 pm
    Hi.
    I have this problem that i imported HD footage into APP but when i play it back the audio is just static. even after i render it. i dont understand what i did wrong. maybe i started a wrong project.
    if it helps here is some info about the files.
    Type: MPEG Movie
    File Size: 215,0 MB
    Image Size: 1920 x 1080
    Pixel Depth: 32
    Frame Rate: 25,00
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:01:14:22
    Average Data Rate: 2,9 MB / second
    Pixel Aspect Ratio: 1,0
    i would be very grateful for any help you could give me 🙂
    Richard Herd replied 12 years, 7 months ago 2 Members · 1 Reply
  • Richard Herd
    January 20, 2014 at 6:44 pm
    If you open the MPEG clip in QT or whatever, does it play there? Can you open the file in Audacity and hear it?
