Activity Forums Adobe Premiere Pro audio from center speaker only
  • audio from center speaker only
    Posted by Doug Harrison on April 7, 2009 at 11:00 am
    hello, using Premier Pro, I exported a typical video like I always do (same settings), burned a DVD as I always do, but I found the first song’s audio only is heard on the center speaker, all other music and audio in other chapters play normally. I have tried using mp3 and wav versions, same results. My export settings haven’t changed, they have always worked. Other music just plain old wavs and play fine. Ever hear a problem like this?
    Thanks very much for the help, I am baffled
    Eddie Lotter replied 17 years, 5 months ago 2 Members · 1 Reply
  • Eddie Lotter
    April 7, 2009 at 4:53 pm
    [Doug Harrison] “Ever hear a problem like this?”
    No. That’s a real head scracther.
    Did you play around with sends in the mixer window?
    Mute the problem audio track and add the same music clip to a new audio track and test.
    Cheers
    Eddie
