Activity Forums Apple Final Cut Pro Legacy Audio Float in Dvcpro50 (24p) capture…
  • Audio Float in Dvcpro50 (24p) capture…
    Posted by Bryce Schoonmaker on August 24, 2007 at 9:23 am
    Tried capturing the tapes as whole just using capture now, with the Dv50 capture presets.
    with a AJ-Sd93 deck via fire wire.
    Looks like anything after 8 minutes or more the audio starts floating….the end rate is something funky like 47.8563 or something. Did a couple test captures, to double check the sync, from 15-60 seconds in length and it held 48khz……
    Not really sure what is the norm for dv50 24p work flows…..
    Any ideas?
    FCP 5.1.4
    G5 Dual 2.5
    4g ram
    ati xt800
    aja IO sd
    Thanks for your time!
    DRtv
    David Roth weiss replied 19 years ago 2 Members · 1 Reply
  • David Roth weiss
    August 24, 2007 at 11:23 am
    [ecyrbsllik] “the end rate is something funky like 47.8563 or something”
    I encountered that same issue a while back. The only solution or workaround I could find was to run the QT files through QT conversion to set the audio sample rate back to 48.00khz.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
