Activity Forums Adobe Premiere Pro Audio Filters Missing From Exported Media File!
  • Audio Filters Missing From Exported Media File!
    Posted by Harrison Gruber on November 3, 2015 at 6:28 pm
    Hey All,
    So I went to export my project, rendered everything. Then when I watched my output file I noticed none of the audio filters I had used (namely the DeNoiser) were there. It was the original terrible unfiltered audio.
    I tried exporting JUST the audio as an AAC to see if the problem was still there when I wasn’t dealing with h264 compression codecs or something and even the AAC file had the problem—no filters. Wierdly I HAD put an audio gain on the original and THAT was preserved. But no DeNoiser.
    Any thoughts?
    Metadata here for my media: (Audio was recorded by onboard mic at 48kHZ)
    Type: MXF
    File Size: 466.12 MB
    Image Size: 1920 x 1080
    Frame Rate: 23.976
    Source Audio Format: 48000 Hz – 16 bit – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:01:15:12
    Pixel Aspect Ratio: 1.0
    MXF File details:
    Wrapper type: MXF OP1a (type: SingleItem SinglePackage MultiTrack Stream Internal)
    File generated by: CANON, EOS C500 (1.00)
    MPEG-2 422 Long-GOP
    Harrison Gruber replied 10 years, 10 months ago 2 Members · 2 Replies
  • Nathan Mcalpine
    November 4, 2015 at 4:38 pm
    I’ve had this same problem. I was doing a ‘quick’ audio fix to a student film with a small budget and I worked through 90 minutes of audio in Premiere. I couldn’t get any of the filters to export. I had to redo the whole thing in Audition. That was a year ago so I was hoping an update had fixed this by now but I only use Audition to add audio filters now.
    Nathan McAlpine
    Commercial Producer
  • Harrison Gruber
    November 4, 2015 at 10:56 pm
    Still not fixed. Boo, Adobe. This has been an issue for over 4 years now.
