Activity Forums Apple Final Cut Pro Legacy Audio Filter
  • Posted by Isabelle on October 4, 2005 at 3:40 pm
    Hi All
    I’m cutting a piece and find myself with a section where the sound is not that good. It’s some live footage of a men talking in a microphone in front of a huge crowd outside. Is there a filter in FCP where I can get rid of some reverberation? Usually I don’t play with the sound in FCP but now I have to.
    Isabelle
  • Bouncing Account needs new email address
    October 4, 2005 at 4:17 pm
    While background hum and certain continuous-type noises are relatively easy to isolate and reduce with special digital filtering…
    Reverb/Echo is one of the most IMPOSSIBLE-to-fix of audio problems, second only to severely CLIPPED (over-driven) levels.
    “EQ” won’t do it.
    Its reverb (repetition) of the PRIMARY audio… the same frequency that you want to KEEP.
    The “Noise Gate” is probably the best choice, but it will surely PUMP if its set high enough to have very much effect on the reverb. (So it could end up making many tracks sound worse.)
    Whatever you try will adversely affect the overall QUALITY of the audio being “fixed” and be very noticeable to the listener (especially compared to any “good” audio in the same production).
    The best choice is to re-record the audio with actors in a quiet studio.
