Activity Forums VEGAS Pro Audio files missing
  • Audio files missing
    Posted by Joel Servetz on February 26, 2013 at 8:47 pm
    I’m using Vegas Pro 10. I recorded a program using a Canon XH-A1S onto a CF card using the Datavideo DN-60. I’ve been using this combo for many projects, importing the video into Vegas and editing with no problem. Suddenly I’m having a problem with this latest project. As always I recorded HDV, saved the file in a folder on my computer and then imported it into my clip bin. If I just open the file outside of Vegas it plays perfectly but when I open it in the trimmer or just drag it onto the timeline, suddenly I only have the first few seconds of audio, even though the video is perfectly fine. I’ve never had this before and I’m not doing anything different. Ideas?
    Joel Servetz
    RGB Media Services, LLC
    Sarasota, Fl
    videobyjoel@aol.com
    http://www.rgbmediaservices.com
    Steve Bertone replied 13 years, 6 months ago 2 Members · 2 Replies
  • Joel Servetz
    February 26, 2013 at 9:05 pm
    I should mention that if I double click on the file outside of Vegas it opens and plays in Windows Media Player with no issues, so I know the audio files are there.
    Joel Servetz
    Sarasota, Fl
    videobyjoel@aol.com
  • Steve Bertone
    March 6, 2013 at 2:16 am
    Hi Joel. Funny enough I’ve run into a similar issue. A 30 min project with many different mp3’s in the timeline, worked and worked perfectly. Played perfectly within Vegas 12 build 398. For weeks that I worked on it. All of sudden I opened the veg, played the preview and can’t hear any audio from the mp3’s. Actually, it all if the mp3’s will play audio from some random video I took. All video that has its original audio will play fine. Video will play fine. But all imported mp3s….no. Very weird. As you said. They all play perfectly in iTunes or wherever else. Not in Vegas though. I uninstalled, and reinstalled and it helped. Then I shutdown comp and when I restarted same problem was there. Other times I reinstalled it didn’t help all the time. Now nothing helps. Let me know if this sounds like your issue at all and if you got it fixed.
