Activity › Forums › Adobe Premiere Pro › Audio Fades on a multiple Audio Track Clip
  • Audio Fades on a multiple Audio Track Clip
    Posted by Dustin Bowser on September 5, 2014 at 3:39 am
    If there is a clip with more than one audio track, like a stereo track that is displayed as multi-mono, is there a modifier key or something that will move both audio fades at once when you’re trying to tweak the fade of a clip. Seems a bit silly that every single time I want to alter the duration of a fade on any given clip that has multiple audio tracks that I have to do it twice, or even more times if there are more channels.
    Paul Neumann replied 12 years ago 2 Members · 1 Reply
  • Paul Neumann
    September 5, 2014 at 5:53 pm
    You can shift click the fades themselves then just double click on any one of them to bring up the duration info box. Enter in the new time and they all should change. Or right click to get to the same box. Unfortunately, it does not work with dragging them out. Only by entering in a specific duration.
