Activity Forums VEGAS Pro Audio fade automatic
  • Audio fade automatic
    Posted by Mike Hite on September 14, 2010 at 4:02 am
    How do you make the audio fade when my transition is applied.
    I have dissolve fade to black transitions that I am using in my movies. The problems is the video part fades correctly, but I can’t get the audio to fade with the approximate time of the transition.
    I want my video and audio to fade for 20 frames everytime I apply the dissolve fade to black transition. How do I make vegas pro 9 do this?
    Maybe there is a better way to do this
    Say you have audio steam 1 and another cut section that you are combining, but the two don’t crossfade well. Is 20 frame fades the best route to use? They don’t mix well, so I am using a 20 frame fade effect, but its still not seamless. You can still hear where clip 1 audio fades and joins. I thought this would be completely faded out when using the approx time of the video fade.
    John Rofrano replied 16 years ago 2 Members · 1 Reply
  • John Rofrano
    September 14, 2010 at 5:25 pm
    If you right-click on the audio fade you will see that there are several fade envelopes to choose from. If you want a faster fade, use a faster envelope.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
