Activity › Forums › Apple Final Cut Pro Legacy › Audio export problem – combines tracks
  • Audio export problem – combines tracks
    Posted by Naveen Mallikarjuna on February 8, 2010 at 3:53 pm
    I have an FCP project with an imported MXF clip (transcoded to 422HQ). The clip has 4 mono tracks.
    I have muted tracks 3 and 4. I’m trying to export export 1 and 2 as stereo (without mixing them).
    I go to Export to AIFF and make sure that “Channel Grouped” is selected. But the exported track has tracks 1 and 2 mixed together. Any ideas why?
    In the Audio Output tab for the sequence settings, the grouping is “Stereo”.
    Naveen Mallikarjuna replied 16 years, 7 months ago 1 Member · 1 Reply
  • Naveen Mallikarjuna
    February 8, 2010 at 6:22 pm
    OK, I think I’ve found the problem.
    I brought up the Audio Mixer. Channels 1 and 2 are set to “0” or center. So I panned them Left (-1) and Right (1).
    Question: Does anyone know how to set this as the default? And also, so that it is global and affects all clips on the timeline?
    Naveen
    contact@naveenmedia.com
    http://www.naveenmedia.com
