Activity Forums Adobe Premiere Pro Audio Export/ fix
  • Audio Export/ fix
    Posted by Tony Bartolucci on December 16, 2005 at 2:06 am
    I’m using adobe premiere to edit some footage shot with a sony vx2000, the audio on the tape turned out a bit lower than I expected so I am going to use sound forge to boost up the volume(unless you guys have a better suggestion). What is the best way to export the audio out of premiere?
    Larry Sherwood replied 20 years, 8 months ago 2 Members · 1 Reply
  • Larry Sherwood
    December 16, 2005 at 3:51 am
    Are you using Premiere Pro? If so, just right click on the audio clip and adjust Audio Gain right on the timeline
    LS
    Larry Sherwood
    Sherwood Post Production
    Austin, Texas
    512 219-8721
    larry@sherwoodpost.com
