Activity › Forums › Adobe After Effects › Audio errors after rendering movie
  • Audio errors after rendering movie
    Posted by Stefan on June 5, 2006 at 4:17 pm
    Hello.
    My final movie contains always errors in the audio track. About all 5 to 10 seconds the sound is somehow doubled. I thought it could be a framerate problem but everything looks alright.
    Here are the facts.
    Source:
    720×576, D1/DV Pal(1,07),Separating(Lower)
    Millions of Colors
    No Compression
    48,000kHz/16bit/Stereo
    25FPS
    Output:
    696×556, Video for Windows Movie
    Millions of Colors
    No Compression
    25FPS
    Did I miss a setting? Thank you very much for any help.
    cheers
    skoller
    Aharon Rabinowitz replied 20 years, 4 months ago 3 Members · 3 Replies
  • Simon Carlson-thies
    June 5, 2006 at 4:34 pm
    Can you export the audio and video as two files and recombine them after the fact?
    That might be better if you haven’t altered the audio…
    Simon Carlson-Thies
  • Stefan
    June 5, 2006 at 6:22 pm
    Thanks for the superquick reply. I tried that, didn’t work.
    If I render the audio-file only, this audio-file contains the same errors. I found out, that these audio-errors are exactly at the same position. The sourcefile is sounds crystal clear. :-/
  • Aharon Rabinowitz
    June 6, 2006 at 4:07 am
    if your sourcefile is an MP3, convert it to WAV or some other uincompressed format before bringin it into AE. AE doesn’t handle compressed audio formats well – so while it sopunds good when you preview, you’re render will sound the way you describe it.
    Also another thing that could be causing it is if you have more than one layer with the same audio. Make sure that in your comp and any precomps there is only one audio layer playing.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
