Activity › Forums › Apple Final Cut Pro Legacy › Audio encode levels
  • Audio encode levels
    Posted by David Achilles on May 24, 2006 at 3:30 pm
    Is it normal within FCP for the audio levels to be correct when encoding (matching the source output) but once you put the clip on the timeline, the audio levels are too low? Everything looks good going into the computer, but once you put it on the timeline, audio is too low.
    How do you fix this or is there a work-around?
    David
    G5 dual 2.7
    2gb ram
    AJA Kona LS
    FCP 5
    David Battistella replied 20 years, 4 months ago 2 Members · 1 Reply
  • David Battistella
    May 26, 2006 at 9:19 pm
    Select the clip in the timeline.
    APPLE KEY>OPTION>L
    This opens a prompt to riase the audio by a specific DB.
    David
