Activity Forums VEGAS Pro Audio Effect to adjust levels
  • Audio Effect to adjust levels
    Posted by David Hajtun on July 6, 2009 at 6:56 pm
    On a regular basis I get several clips with different levels of audio and have to go through each one and adjust so the all come out with the same level. Is there an effect that will automatically adjust each level to the same output? Perphaps I can creat a preset and apply to the entire track?
    Hope this makes sense…
    Thanks for any help,
    David
    David Hajtun replied 17 years, 2 months ago 3 Members · 4 Replies
  • Theo Van laar
    July 6, 2009 at 11:03 pm
    Sony’s Production Assistant has a very easy function which will do this job: Normalize Track.
    Theo
  • Theo Van laar
    July 6, 2009 at 11:34 pm
    There is also a free script (author unknow) available: Normalizeall.js. Maybe this script will work with your version of Vegas.
    127_normalizeall.js.zip
    Theo
  • Stephen Mann
    July 7, 2009 at 4:58 am
    I use a free program called: Levelator. Here’s a line from their website:
    “Do you believe in magic? You will after using The Levelator to enhance your podcast. And you’ll be amazed that it’s free, now even for commercial use.”
    I use it on every production and continue to be amazed how much better my audio tracks sound.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • David Hajtun
    July 8, 2009 at 2:50 pm
    Thanks to all…I will give them a try…
    Peace
