Activity Forums Adobe Premiere Pro Audio Dropout Mid Clip
  • Audio Dropout Mid Clip
    Posted by Kian Mckellar on June 2, 2012 at 3:47 pm
    I’m editing a project on Premiere CS6 and I’m having an odd audio problem. For long clips the audio simply disappears midway through the clip. I know the audio is there because I play play it on the camera and in Final Cut.
    My theory is that I was running out of space on my laptop cache and it simply gave up on those audio clips. Premiere seemed to act oddly when conforming by going back to clips several times but I got no error message.
    Any ideas what this problem is and how I can remedy?
    Greg Jones replied 14 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Greg Jones
    June 2, 2012 at 7:26 pm
    I’m having a similar issue where the audio drops in and out. I’m going to try and trash my prefs and see if that helps
    Greg Jones
    D7,inc
  • Ryan Patch
    June 2, 2012 at 10:00 pm
    I think you’ve hit on this issue:
    https://forums.creativecow.net/readpost/3/925414
    Unfortunately, I have not found a solution.
  • Wendell Davis
    June 3, 2012 at 3:49 pm
    I too have the problem on occasion. If I stop and play again the audio is back. Sometimes I close the project and reopen it – that works.
  • Kian Mckellar
    June 3, 2012 at 4:09 pm
    Actually it isn’t similar. The audio doesn’t drop in and out, it plays for a while and then dies. The waveform reflects this. All of the other audio from shorter clips works completely fine but the longer clips tend to have their audio die mid way.
  • Ryan Patch
    June 3, 2012 at 4:41 pm
    Try deleting your .cfa files for the media in question, and then don’t mess with the project until they are done re-conforming.
  • Kian Mckellar
    June 4, 2012 at 1:20 am
    Oddly enough I loaded them up on my desktop and it worked instantly. No new conforming or anything. *shrug* Going to go back and forth between the two and hopefully figure it out so it doesn’t happen again.
  • Greg Jones
    June 4, 2012 at 12:57 pm
    I think I’ve narrowed down the issue. When I’m in Premiere Pro CS6 and I open up a 720p 59.94 ProRes Clip in the Source Monitor it plays perfectly. When I drag it to my sequence, it starts to act wonky. The sequence I created was a Pro Res sequence and I drag the clip down to it and it asks if I want the sequence to conform to the clip. I click yes. This is the wonky sequence.
    I created a second sequence and clicked no to the conform to clip and now my stuff plays perfectly. Not sure what’s going on , but I may have a temporary solution.
    Greg Jones
    D7,Inc.
    Greg Jones
    Orlando,Fl.
    https://www.d7-inc.com
