Audio drift problem
I am trying to sync footage of dancers dancing to a track up to the very same track in fcp. However I am getting audio drift of about 10 frames by the end of every song (so the beginning starts out synched up, then the end is somewhere between 5-10 frames different). I was the one who shot some of the footage, so I can tell you the following:
Footage was shot at 60i (29.97 fps), was captured into FCP at 29.97 fps, and is in a sequence set to 29.97 fps. The audio is 16-bit stereo, 44.1 kHz.
I have done this three times before and it has worked fine (same exact settings on the camera, on the logging and on the sequence).
Any ideas what could cause sudden audio drift like this? The track the dancers are shot dancing to is the exact same track I’m using in fcp, everything should pretty easily match up, so I’m really baffled.
