Activity Forums Apple Final Cut Pro Legacy Audio Drift – black at end of clip
  • Audio Drift – black at end of clip
    Posted by Ed Cilley on October 23, 2008 at 1:45 am
    Here is a weird one.
    Captured BetaSP footage via AJA IO into FCP 6.0.4.
    While playing back the clips, audio immediately starts to drift. Towards the end of the clip, video goes to black and audio continues. The same is true for clips 19 seconds long or 3 minutes long (the black is proportional to the length of the clip).
    Here’s the weird thing. The QT clips play fine outside of FCP — they are in sync in the QT player. Inside FCP the audio drifts and is out of sync. If I import these same clips back into FCP, the same problem continues. If I open in QT and Export using same settings (basically making a copy), the exported version plays fine in FCP.
    I have uninstalled the AJA IO software. Trashed my FCP preference using FCP Rescue 6. Restarted. Launced FCP, changed Playback Control;Frame Offset to 0. Still have same issue.
    Anything worth doing at all, is worth doing well.
    Jeremy Garchow replied 17 years, 10 months ago 3 Members · 22 Replies
  • 22 Replies
  • Jeremy Garchow
    October 23, 2008 at 2:47 am
    Does your sequence match your captured settings? Sounds like it doesn’t.
    Jeremy
  • Ed Cilley
    October 23, 2008 at 2:52 am
    Jeremy, this is happening in the Viewer window. I didn’t even get to making a sequence yet.
  • Jeremy Garchow
    October 23, 2008 at 2:53 am
    Try making a sequence and see what happens.
  • Ed Cilley
    October 23, 2008 at 11:51 am
    Same thing with a sequence.
    ______
  • Jeremy Garchow
    October 23, 2008 at 2:53 pm
    OK.
    What versions of everything are you on and what easy setup did you use? What frame rate is your timeline and what frame rate is your footage?
  • Ed Cilley
    October 23, 2008 at 3:50 pm
    The problem has nothing to do with the sequence. The clips played in the Viewer show the problem. But, it was NTSC DV 48kHz.
    I’m not in front of that computer so forgive me for some details.
    OS 10.5. (.4 i think – not the latest)
    FCP 6.0.4
    QT 7.4.?
    Won’t be able to give exact details until tonight – I appreciate your help with this.
    _________
  • Jeremy Garchow
    October 23, 2008 at 3:56 pm
    [Ed Cilley] “The problem has nothing to do with the sequence.”
    I can only trust you on that.
    Did you use an easy setup when you captured with the io? Do you have multiple firewire devices connected to your machine along with the io?
  • Ed Cilley
    October 23, 2008 at 7:24 pm
    Capture setting on IO was Component Betacam to DV 48kHz.
    IO is only Firewire device. HDD is via eSATA.
    _____________
  • Jeremy Garchow
    October 23, 2008 at 8:18 pm
    Have you uninstal and installed the latest io driver from AJA that includes the firmware update?
    Jeremy
  • Ed Cilley
    October 24, 2008 at 12:37 pm
    Yes, I have uninstalled and reinstalled the latest AJA software — and uninstalled again, not using AJA for playback. Same issue.
    I have NOT uninstalled the firmware (not sure how to do that).
    My work around has been to create new clips by either Export from QT, or using Compressor. I simply duplicated the settings of the original clips (which if you remember play fine in QT) and made new files.
    I also tried starting a new Project. Imported the clips into that project. When played in the Viewer, same issue. Import the new copies and they play fine.
    _____________
Page 1 of 3
