Activity › Forums › Adobe Premiere Pro › Audio doesn’t play
  • Audio doesn’t play
    Posted by Kevin Kimman on December 16, 2010 at 10:20 am
    Hey,
    I’ve got a strange problem with my audio in Pr CS5, or at least i think i do.
    all the audio works just fine wherever I play it in, even when I double click the file in the bin and
    it previews in the window. But as soon as I drag it into the timeline it goes silent.
    It does peak on the audio meter though. I just can’t hear it.
    It happend just this week, I never had this issue before.
    Any suggestions? It’s kinda hard to edit like this.
    Kevin Kimman replied 15 years, 9 months ago 2 Members · 2 Replies
  • Vince Becquiot
    December 16, 2010 at 9:50 pm
    Hi Kevin,
    What type of sound card are you using? Is this a stereo sequence?
    Also, check your audio output mapping in your preference and make sure that it is set to the correct output.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Kevin Kimman
    December 27, 2010 at 2:08 pm
    Hey Kaptis,
    Thanks for your answer, al my settings were OK, both output mapping, audio settings aswel as the settings on the mac itself. It turns out that I used de 1080P sequence preset of blackmagic design, and apparently if you do not have a blackmagic audio card or something it just won’t play our audio.
    Didn’t think that it would be an issue.
    Thanks anyway, problem solved.
