Activity Forums Adobe Premiere Pro Audio does not nest
  • Audio does not nest
    Posted by Bella Gavelin on October 7, 2016 at 9:07 am
    When nesting a group of clips with a lot of audio underneath, only the video is “grouped together” on my timeline. The audio stays the same (is not nested). Although, when I enter the nested sequence, the audio is all there. I want it to group itself into one clip on my original timeline, just like the video does.
    Workaround is to drag the newly nested sequene into the original anew, but I don’t want to be dragging and deleting things. Halp!
    bella
    Peter Garaway replied 9 years, 11 months ago 2 Members · 1 Reply
  • Peter Garaway
    October 7, 2016 at 6:13 pm
    Hey Bella,
    The method your using as the workaround is the only way to nest video and audio together. Please file a feature request if you want (and I’m sure you do) to be able to next video and audio together without bringing it into a new sequence.
    https://www.adobe.com/products/wishform.html
    For folks wanting a visual look at what Bella brought up check out this video:
    https://vimeo.com/user5548295/nesting-audio-in-premiere-pro
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
