Activity › Forums › Adobe Premiere Pro › Audio distorted
Audio distorted
Posted by Matt Voye on June 9, 2023 at 1:12 pmI have an audio file taken from a video clip that have an under water distortion quality to it. Any tips on how to clean it up to help preserve the people speaking?
Mads Nybo jørgensen replied 3 years, 3 months ago 4 Members · 4 Replies -
Hector Vera
June 9, 2023 at 9:00 pmIt all depends on how loud or low that water distortion is. There could be ways around it to lower the distortion but not without it affecting a bit on the sound quality that you wish to keep too, a reducing noise effect in Premiere Pro will help. I can help look it up later on to see how you can access it if you want.
Mads Nybo jørgensen
June 13, 2023 at 2:33 amHey Matt,
Out of interest, where did your clip originate from?
Was it from a tape-deck where the sync/tracking was out?
That could give you that kind of play-back – same with old audio-reel editing solutions.
Rare, but possible.Although not a “pure” solution. If there isn’t a plug-in that can repair it. You could consider re-generation the voice using one of the many “text to speech” engines on the internet – some will also match the actual voice.
Mads -
William Ogah
June 21, 2023 at 3:42 pmHi Matt, My name is William and I am new here. I am like new to both video & audio editing. I have one that needs an experts attention as I have exhausted everything I tried doing on my own, hence I discovered creative cow and joined. Could you be of immense assistance to me to edit an audio by removing the music to remain only the voices of the individuals at the background? Thanks. williamogah23@gmail.com
Mads Nybo jørgensen
June 21, 2023 at 11:07 pmHey William,
Welcome to the COW!
Can you share a clip with us + a bit more background information?
Like, why do you need the music to be removed?
Is the music on the original footage, or was it added later?
And, there are ways of reducing the loudness of the music, or masking it, but it will be more complicated if you want to completely remove it.Atb
