Activity Forums Avid Media Composer Audio Digitizes to Left Channel-Mixed????
  • Audio Digitizes to Left Channel-Mixed????
    Posted by Paul Factora on September 25, 2007 at 5:57 am
    Everything I’ve checked from the Deck to the Audio Tool to my Capture Settings indicate I am capturing the 1 & 2 channels Left & Right.
    But as I play the clip the both channels will mix to Channel 2 and Channel 1 is deck noise.
    what could I be missing here?
    Paul
    Joe Womble replied 19 years ago 3 Members · 2 Replies
  • Jon Zanone
    September 25, 2007 at 10:06 am
    Deck noise? Is it possible you have one of your audio cables hooked up to the TC out?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Joe Womble
    September 26, 2007 at 11:56 pm
    If this good technical advice from Jon doesn’t fix it for you, try creating a new user and user settings. Sometimes Avid gets confused or confounded, and starting with “fresh” settings can fix unusual errors.
    Regards,
    Joe Womble
