Activity Forums Blackmagic Design audio delay sinc premiere pro
  • audio delay sinc premiere pro
    Posted by Masashi Sato on July 30, 2007 at 6:25 pm
    hi,I use Decklink HD Extreem on premiere pro CS3.
    I monitored videos on TV through conponetRGB and XLR anolog audio.
    but,I appear to have a 15 frame delay.
    Can I adjust this?
    Decklink HD Extreem
    windows xp
    intel 975 xbx2 Q6700 memory 3G decklink driver6.3
    Masashi Sato replied 19 years, 1 month ago 2 Members · 3 Replies
  • Kristian Lam
    July 31, 2007 at 12:25 am
    If you’re monitoring out via the card’s video and audio output, then you should not have syncs. This might happen if you monitor video via the card but audio via the PC’s sound card.
    Are you using one of the presets we’ve provided to configure your project?
    regards
    Kristian Lam
    Blackmagic Design
  • Masashi Sato
    July 31, 2007 at 5:44 am
    Thank you.
    I used Decklink’s XLR conector,and Decklink’s conponentRGB conector.
    I created Project files Blackmagic DV preset.
    I selected PremierePro windows sound at [edit-preference-audio hardware].
    but, over 15 frame delay.
    When I selected Decklink Audio at [edit-preference-audio hardware],
    no sound at Decklink’s XLR conector.
    I have to install additional ASIO driver?
  • Masashi Sato
    July 31, 2007 at 7:28 am
    I get sync audio and video.
    I’m sorry.
    I selected Decklink audio at[windows-controlpanel-sound device-audio-default device]
    I changed this pulldown to SigmatelAudio(on-board sound chip),
    and select DecklinkAudio at [premiere-edit-perference-audiohardware].
    Then,I fix the problem.I get sync audio.
    thank you for information. bye
