Audio Delay out of Final Cut Pro X with Aja iO ST
I’m running a mac pro with 11.0.2 operating system. The last couple of updates have created an annoying problem. Monitoring the output on my broadcast monitor via an Aja IO XT, I have a two to four frame delay coming out of the system to the broadcast monitor. I cannot find an adjustment for this. The output of the machine is fine when I render, it’s just a monitoring problem.
Is there not an adjustment within Final Cut Pro to compensate for this? Seems that would be a basic feature.
_______________________________
Mark Maness
Strike King Lure Company
mmaness@strikeking.com
